Hi guys,
I was able to successfully install macOS Big Sur on my dual boot PC with Windows 10.
MoBo: X570 Aorus Elite
CPU: 3700X
GPU: Red Devil 5700XT
RAM: Ballistix 16GB 3600Mhz CL14
SSD: Crucial 480GB
OPEN CORE 0.7.1
EFI.
ACPI:
SSDT-EC_USBX-DESKTOP
SSDT-XHC
DRIVERS:
HfsPlus
OpenCanopy (GUI boot)
OpenRuntime
KEXT:
AppleALC (alcid=69)
Lilu
SmallTreeIntel825
VirtualSMC
AMDRyzenCPUPowerManagement
SMCAMDProcessor
WhateverGreen (agdpmod=pikera)
TOOL:
OpenShell
RESOURCE: is from here
macOS Big Sur - 11.5
BIOS: F30
OS UPDATE:
Updated to 11.5.1 - bug on some automatic wallpapers.
*// Updated to system preferences. After reboot launch Macintosh HD partition.
Updated to 11.5.2 - fix bug on some automatic wallpapers.
*// Updated OpenCore 7.2 + Kext
Audio, internet and graphics work without problems.
I can't test AirDrop but network sharing with other Macs works and also the sharing and synchronization functions with other Apple devices.
All USBs work
Front jack work.
NOT WORKING:
iMessage
Microphone
DOWNLOAD MY EFI FOLDER BELOW:
Instructions: Open the config.plist file with ProperTree. Go to the "PlatformInfo" section and enter your smUUID and your serial number. I left the default ROM number. Use GenSMBIOS to generate the codes to use. RESET NVRAM.
I TAKE NO RESPONSIBILITY for DAMAGE to your computer and / or LOSS DATA. It is always best to configure your own EFI folder.
Speedtest ok with other devices.
AMD Power Gadget:
Cinebench
If you use the attached EFI folder write it in the topic by entering your configuration; if you make changes to the folder, or have suggestions and advice that can help me or other people looking for info, write it in the topic. The software we use and the information we receive are free. Share your experience, don't just think about yourself.
I will update the topic after any changes or feedback.
SPECIAL THANKS FOR THE HELP TO AudioGod - Shaneee.
Thank you all.
CPU: 3700X
SSD: Crucial 480GB
OPEN CORE 0.7.1
EFI.
ACPI:
SSDT-XHC
DRIVERS:
HfsPlus
OpenRuntime
KEXT:
AppleALC (alcid=69)
Lilu
SmallTreeIntel825
VirtualSMC
SMCAMDProcessor
TOOL:
OpenShell
BIOS: F30
OS UPDATE:
All USBs work
Front jack work.
NOT WORKING:
iMessage
Microphone
AMD Power Gadget:
Cinebench
Thank you all.
