So remove 1 patch and add 1 patch.
There’s more than one to remove. Check the patch names I posted. You need to remove them all or they will conflict.
My pea brain isn't processing the remove "cores and logical count < For 10.13" - is this a removal of all cores & logicals, just 10.13, or < # 2,3,4?Here's the temp way to update to beta 2 / 3 until the PR is merged.
Patches to remove:
- Update to latest patches on GitHub. FORCE_PENRYN was updated.
- Remove any patches relating to cores. There's a list at the bottom of this post.
- Add in a core count patch based on my OC PR, also listed at the bottom of the post
- Boot
Code:Don't set cpuid_cores_per_package Skip _cpuid_cores_per_package test jmp to calculations and set cpuid_cores_per_package cores and threads calculations cores and logicals count < For 10.13
New patch:
Code:Comment: Force cpuid_cores_per_package Base: _cpuid_set_info Find: C1E81A000000 Mask: FFFDFF000000 Replace: BA CoreCount 00000090 ReplaceMask: FFFFFFFFFFFF
CoreCount = Your CPU Physical cores in Hex.
- 6 Core = 06
- 8 Core = 08
- 12 Core = 0C
- 16 Core = 10
- 32 Core = 20
We love youI've been working on a SmallTree modification; it seems close. Shown in the attached image is how the modified SmallTree kext binds to the proper site in the left side (IORE) and how the port is now recognized in HackCheck app (upper right), but the port is inactive in Network Utility app (lower right).
Meanwhile, the Aquantia port works with a new patch for Monterey. Also, I've gotten BT and Wifi to work on ß1, and so AirDrop works as well with ß1 as I reported on a TRX40 thread on the macOS86 forum.
But I've only been able to test the modified SmallTree on my TRX40 mobo under ß1 (as I'm too lowly and undeserving of patches for anything > ß1).
Once I get patches for ß3, and if it works, I'll share the modified kext. The kext is currently being tested together with a custom SSDT file. (There's another avenue of approach to the problem, but I don't want to bother with it until I see if ß1 is the problem.)
And I have additional question,My pea brain isn't processing the remove "cores and logical count < For 10.13" - is this a removal of all cores & logicals, just 10.13, or < # 2,3,4?
Should we add "Arch:", "Count:", "Enabled:", "Identifier:", "Maxkernel:", "Minkernel:" and "Skip:" with new patch?
Arch: x86_64
Count: 1
Identifier: kernel
MinKernel: 17.0.0
MaxKernel: 21.99.99
Skip: 0
Thank you!Yes otherwise OC will complain they are missing.
Code:Arch: x86_64 Count: 1 Identifier: kernel MinKernel: 17.0.0 MaxKernel: 21.99.99 Skip: 0
Yes! I can boot on windows11, Big Sur, and Monterey using the OC boot loader with trimmed patchesCan you boot beta 1,2 or 3? After trimming and adding the patch?
When I tried I got stuck on Apple logo.
Can you share new patches please. Also how many cores you have?
mackintosh HD is the installation, select thatInstalling now, so far so good. It boots and is installing Monterey B3, not yes tested other OS.
Hmmm booted back to beta 1, after first reboot so I select Macintosh HD or the Monterey volume?
you should have same OC bootloader version installed on big sur and monterey, say if you use 0.7.1 on monterey then use the same version on big sur, dont forget the bios settingsWith the patches that work perfectly on Monterey I can now longer boot Big Sur. Hangs at Apple logo.
It’s certainly not a deal breaker but would be nice to have BS boot too.
