Mac Os Installer
krasnoe yabloko
Hello,
tell me, is it possible to install Mac OS on this hardware and which version is better?
Characteristics :
Graphics card - ASUS RX 460 2 GB
Processor - AMD X4 Athlon 880K Turboboost
Motherboard - A68HM P33 V2
RAM - HyperX Kingstone 8 GB 1600 MHz - 1 pc.
Thank you for your help!
krasnoe yabloko
If I'm correct in thinking it's a 15h CPU so you can install Big Sur if you'd like. Use the Dortania guide here, https://dortania.github.io/OpenCore-Install-Guide/
Hi, ye its 15h processor. I tried to install Big Sur. Created a config from scratch for this system. An image has been created through the Open Core - macrecovery guide. But it gives this error.
AAPL: #[EB.LD.LF|IN] 0 1 <"<null string>"> <"1">
AAPL: #[EB.B.SBS|SZ] 739896
AAPL: #[EB|B:SHA] <43e5e81850f6f41533129fc07c176a5eb714c9be>
AAPL: #[EB.WL.PWLFNV|!] Err(0xE) <- RT.GV wake-failure 7C436110-AB2A-4BBB-A880-FE41995C9F82
AAPL: #[EB.WL.DT|!] Err(0xE) <- EB.WL.PWLFNV
AAPL: #[EB|WL:DT] 0xffffff7f
AAPL: #[EB.LD.LKC|R.1] <"System\Library\KernelCollections\BootKernelExtensions.kc">
After hanging.
I also tried catalina.
AAPL: [EB|#MBA:NV] (-v keepsyms=1 debug=0x100 npci=0x2000 slide=106)
AAPL: [EB|#MBA:KF] ()
AAPL: [EB|#MBA:OUT] (-v keepsyms=1 debug=0x100 npci=0x2000 slide=106)
AAPL: [EB|#LOG:VERBOSE] 2021-07-05T09:29:26
AAPL: [EB|`CSR:S] csr-active-config = 0x00000040
AAPL: [EB|#OPT:BM] 0x825082
AAPL: [EB|`OPT:LXF] 'LF (\\System\\Library\\CoreServices\\PlatformSupport.plist)
AAPL: [EB|`LD:LF] FIO: 0, DIR: 1, P: \\System\\Library\\CoreServices\\PlatformSupport.plist, DP: 0
AAPL: [EB|#B:VAw]
AAPL: [EB|`B:MN] BM: ROS
AAPL: [EB|#WL|6] 0x01 0x01 19 0x0E
AAPL: [EB|`CS:CSKSD] {
AAPL: [EB|`G:CS] } Ok(0)
AAPL: [EB|`LD:LF] FIO: 0, DIR: 1, P: <null string>, DP: 1
AAPL: [EB|`B:SBS] SZ: 621112
AAPL: [EB|#B:SHA] 4f3bba9614aa0dbae1943ab55b83beac7e278986
AAPL: [EB|`WL:pWLFNV] Err(0xE) @ GV wake-failure
AAPL: [EB|`WL:DT] Err(0xE) @ WL:pWLFNV
AAPL: [EB|#WL:DT] 0xFF 0xFF 255 0x7F
AAPL: [EB|`LD:LKC] BM:R -> (System\Library\PrelinkedKernels\prelinkedkernel)
After hanging.
Use Kext - the order in the config is respected.
1)Lilu
2)VirtualSMC
3)AppleALC
4)Realtek8111
5)WhateverGreen.
The KFG setup was through the ProperTree. Instruction for 15 / 16h. Kernel patches have been replaced.
Upload your EFI and I’ll take a look later
krasnoe yabloko
  • EFI.7z
krasnoe yabloko
  • logs.7z
Try this
krasnoe yabloko
Hello, I tried this config. The error is the same, only characters were added after the "GV wakeup failed". This config has been tested on Yosemite, El Capitan, Mojave, High Sierra. I tried the default BIOS settings and set the settings according to the guide - it had no effect. It might be worth trying a different Mac Os ISO file.
When tested on Yosemite, Mojave, High Sierra. The text appears in one line "End ConsoleMode". And on El Capitan, Big Sur stops at the core panic.
Replace the config with this one and try.
