Ryzen 3900 | ASUS STRIX B350-I Mini-ITX | ASUS STRIX RX5700XT | Catalina 10.15.5 | OC 0.5.9 | Multi Core: 8437 Metal: 75028 | Fractal Design Note 202
blackmag
7
Hello everyone from Russia! So after 3 days I at last finished install the system and system works!
In total everything working well, here some things that doesn't work:
1) Sleep.
2) When macOS starts, alert shows that i installed more than system allows to install, I have 16gb RAM and MacPro (2019) supports much more) so I don't know what to do but it not affect to system stability it just an alert. Perhaps it my fault in config.plist if you know how to fix this you can reply bellow.
3) Some programs for example DaVinchi Resolve Studio and After Effects crashes at start. PhotoShop, Premiere, Media Encoder, Final Cut Pro works normally.
4) When I click "About This Mac" and click "Memory" thereafter the window just disappears.
UPDATE: Solved problems 2,3,4.
Full specs of my system:
SMBIOS: iMacPro1,1
OpenCore: 0.5.9
Сase: Fractal Design Note 202
Motherboard: ASUS ROG STRIX B350-I GAMING Mini-ITX
CPU: AMD Ryzen 3900
GPU: ASUS ROG STRIX RX5700XT
RAM: Kingston Fury 8GB and Geil Evo X 8GB 2933MHz
SSD 1: Samsung EVO 970 M2 NVMe 250GB (For Windows 10)
SSD 2: Intel 760p M2 NVMe 512GB (For macOS)
External HDD: Toshiba Canvio 4TB (For Trash)
Power Supply: Corsair SF750 Platinum
CPU Fan: Noctua 120x15mm
Heat Sink: ID COOLING IS-60
Geekbench 5:
Single-Core: 1232
Multi-Core: 8982
OpenCL: 44724
Metal: 75028
I'll be grateful if you can help me solve some of my problems. Thanks! :)
