Solved Discord crashing
BomBayGini
56
11
Ryzen 9 5900X
I have installed discord and when I use the mic open setting it’s crashing the app, to fix that you need to change the mic setting to push to talk.
But when I share screen it’s crashing also.
Someone know how to fix that ?
there’s nothing to it really just copy the environment.plist file into $HOME/Library/LaunchAgents/ and reboot
See nothing to it really just copy the environment.plist file into $HOME/Library/LaunchAgents/ and reboot
Ok thanks I’ll give it a try when I’ll be at home
Reactions: AudioGod
it worked good thanks a lot !
Reactions: AudioGod
