Solved Intel bluetooth not detected
brendan_siow
25
Hi guys, I am currently using Opencore 0.7.0 and I wish to work on my bluetooth.
I bought an Intel AX210 WiFi + Bluetooth (Fenvi AXE3000).
1. There is no information in my bluetooth
2. I tried mapped all the USB but I only found USB ports for USB controller. I removed extra USB and set XhciPortLimit to false. However, I cannot find any internal USB (that suspect to be bluetooth) neither in Hackintool or IORegistryExplorer. Thus, I haven map my Bluetooth as 255 yet.
3. I installed both IntelBluetooth kext but Hackintool doesn't show that the Kexts were being loaded.
Anyone can help me with this? Thank you in advance. ❤️
If you haven’t mapped Bluetooth via usb then it will not work.
If it’s not showing up at all then power down the system and remove the power cable from the wall, Wait a few minutes then plug it back in and boot back up and that should make your Intel wireless card kick into life.
Also a B450 Motherboard has two USB controllers so port limits shouldn’t be an issue. It’s 15 ports per controller not per system. 👍
Did you also add the kexts to your config? Also injector only kexts don't show as loaded.
I wanted to map the Internal USB for bluetooth but I just cant find it.
Maybe I understand it wrongly, oh I see its 15 per controller, the weird part i found is my Hackintool show two USB controller but in motherboard one is plugged with USB and one is plugged with my Bluetooth.
I tried shutdown completely many times and still the internal USB doesn't show up. The wireless card is not going to work as its not supported yet (AX210), but at least in PCIE list, I am able to see it here... But Bluetooth with Internal USB just missing.
yes yes, I added them to config.plist.
Hmm thanks for telling that injector kext shouldnt be showing here. 🙏
But the IntelBluetoothFirmware also not showing as installed ><.
The Lilu seen as highlighted here meant installed if I am not mistaken
I think for Boolean you use True(Yes) or False(No).
Enable Boolean = True
Reactions: brendan_siow
SOLUTION:
My bluetooth missing because the USB port is missing, I follow OpenCore guide to reset USB Controller and the bluetooth appear. Then I mapped my Bluetooth USB as internal.
Btw, since I am using AX210, I need to use IntelBluetoothFirmware v2.0.0 RC1.
And yes.... bluetooth works ❤️
Thanks all of you for helping. 🙏
