[PleaseHelp]
530549814
R5 2600 + GIGABYTE B450M DS3H + RX560 + SANSUMG 750EVO + 16GB MEMORY
Hi,i successfully install the macos 11.5,but mechanical keyboard working not good.
when i press the keyboard but output another key on the screen.
eg:when i press 'a',but output 'h'.
how can i fix it?
here is my efi.
keyboard model:asus strix tactic pro
CPU:R5 2600
Motherboard:GIGABYTE B450M DS3H
thank you for your help.
Before you start messing with the EFI... your system boots correctly, right?
In macOS, check System Preferences > Keyboard > Input Sources what kind of keyboard layout you have installed. If it's just a regular QWERTY keyboard, something like 'U.S. International' should do. If you need a region specific keyboard layout you can select it there.
how can i fix it?
here is my efi.
CPU:R5 2600
see if the usb port driver is installed correctly with no errors
