ENABLE SVM ON BIG SUR (IN BIOS IS ENABLED)
djlkz
Hi guys, i have problem with using AVD (android virtual devices) on android studio, i try enable SVM option in BIO, in windows works normally, but in macOS not running.
Olá galera, tenho um problema para utilizar o AVD emulador do android studio, eu já ativei o recurso SVM na bios, no windows funciona normal, mas no macOS não estou conseguindo rodar o emulador.
RAYZENTOSH Settings
OPENCORE 0.7.0
RYZEN 3900X
XFX RX 580 4GB (MACOS BIG SUR)
GIGABYTE GTX 1080 (WINDOWS 10 PRO)
XPG D60G 3600MHZ 16GB DUAL
ASUS X570 TUF GAMMING
It won't work on an AMD machine I'm afraid. It uses Apple's Hypervisor which was built for the Mac, so it requires an Intel CPU with VT-x not AMD with SVM.
djlkz
Não funcionará em uma máquina AMD, infelizmente. Ele usa o hipervisor da Apple que foi construído para o Mac, portanto, requer uma CPU Intel com VT-x e não AMD com SVM.
Tnx, i solved this with armb room in avd or genymotion.
grad1e
grad1e
Genymotion was laggy as hell for me. I've resorted to using SCRPCY with my phone connected
