Installation stops at 12 min remaining and then it reboot: AMD Threadripper 3960x + AMD RX 6900XT
Cosmin
When I try to install latest Big Sur Beta 14.4.1 with OpenCore 0.6.8, the installation stucks at 12 min remaining. The keyboard and mouse freeze and all I can do is force shutdown.
My configuration is:
Processor: AMD Threadripper 3960X
Motherboard: Asus ROG Strix TRX40-E Gaming
RAM: 128 GB 3200 MHz
GPU: Asus AMD RX 6900XT
I'm attaching the EFI folder and the installation log file.
  • opencore-2021-05-05-232352.txt
Have you checked your BIOS settings? If they are correct try installing again but open the install log and set it to show all messages. When it freezes share an image of where it's stuck.
Cosmin
I attach the install log image of when is stuck
Nothing sticks out there. When you reboot are there any extra boot options in OpenCore?
agent2
Do you want to try OC0.6.9? I haven’t looked through your EFI yet but it worked a charm for me getting the beta installed.
Cosmin
No, there are exactly the same boot options like on first boot.
Cosmin
I'll try with v. 0.6.9 tonight and I'll post the result.
Cosmin
I tryed with OC 0.6.9, and the same results, except the computer restart itself instead freeze. Also there is no other option added to boot option.
I really don't know where the problem is...
Cosmin
I already tryed with OC 0.6.9, with Big Sur 11.4 and then 11.5 beta.
Many of you tried to help me, but still the same problem: it restarts automatically at installation's screen 12 min remaining time, and the OC boot menu is the same like first install.
divakar7c5
Hi @Cosmin,
I'm also facing same issue. My configuration is similar to yours.
Were you able resolve this? I'm a newbie, Could you please give some pointers?
My Configuration:
Asus ROG Zenith II Extreme Alpha
Corsair 64 GB RAM - 3200 MHz
1 TB SSD PCIe Gen. 3
Nvidia GTX 710
Corsair AX 1200i Power supply
Cosmin
Hi @Cosmin,
My Configuration:
Nvidia GTX 710
See the other post please: here
I think u could try to use my EFI, but have attention on your videocard - it'sNvidia not AMD.
