It go further but I have a new problem:You have secure mode turned on, so you need to set up a vault. There is a routine in the Tools folder which does it for you.
I dont know, whats the OC picker. I choosed my bootable USB Stick. I also saw this screen ( picture).You've booted to the UEFI Shell. Did you get to the OC picker?
Now I can chose. I chose Mac Os external. But now I have a grey screen ?!That's the picker. So your macOS options aren't showing. In your config.plist change the ScanPolicy to 0 and reboot.
I made a new config list. Now it goes further but it stops here.Are you booting with verbose? Also check your patches for AMD are present and correct.
I also changed the graphics card to game mode, it made a difference. But now I have a new problem:Either try with Above 4G decoding enabled or addnpci=0x2000
to the boot args
