Crossover 19 on Catalina
mjgha
Having problems with installing applications on Crossover 19. When trying to install and app, majority of the tasks fail... Anyone else having these problems? Solution?
3700x
saphire nitro+
asus rog strix 470-i
Are there any error logs for it? What does the app do?
mjgha
Hi, Shaneee,
Thanks for the quick reply.
I have attached a cxlog, and a screenshot of an example... It just mentions task failed, this happens for 80% of the items it tries to install.
Curious to hear your thoughts.
Thanks.
  • Install-MetaTrader 4 6.cxlog.zip
It seems like it's either looking for 32-bit binaries which won't work on Catalina. Or it's looking for an Intel specific instruction. Neither we can fix.
mjgha
I believe it is looking for the intel specific instruction. Anyway, thank you for helping out!
