First Build - Freeze at Apple Logo
SeanMeade1
Hello!
I'm working on making my first Hackintosh and when I get to the boot menu, I click the Mac OS, but it freezes at the Apple Logo
Ryzen 9 3900x
ASRock X570 Creator Motherboard (Really need to have both the USB-C ports in the back working
GSkill Trident Neo 2x32RAM
Gigabyte Radeon Vega 64 GPU
Western Blue NVME M.2 SSD
Working on running 10.15.4 off of Opencore. Can attach my config.plist if needed!
Thank you!
SeanMeade1
I entered -v to get errors visible and the following are the prominent issues I think:
v1.0 matches prelinked kext but can't determine if executables are the same (no UUIDs)
Can't perform kext scan: no kext summary
Mac OS version: Not yet set
Panic diags file unavailable, panic occured prior to initialization
rx3700
Have you checked your BIOS Settings? My boot freezes when I have CSM Support enabled, so you might wanna disable it.
Sounds like you are facing a kernel panic. Boot with Verbose and post an image of the screen when this happens.
SeanMeade1
Thanks, yeah I ended up figured the kernel panic situation...now I'm just stuck at the USB mapping and the terminology is killing me as someone who knows little to none about readingin MaciASL.
You've got an X570 board so use this for USB Mapping,
  • SSDT-XHC.aml.zip
