X570s Riptide Fenvi bluetooth not working.
Neal Caffrey
Hai, does anyone have tried using Asrock x570s Riptide mobo?
My current setup is
Asrock x570s Riptide Mobo
Ryzen 9 5900x
RX6800XT
Fenvi T919
Currently using Opencore v0.7.7.
All kext update to latest version.
My problem is, after i change my mobo. Fenvi bluetooth is not working. Seems like it not detected my bluetooth device.
Wifi and airdrop all working fine except bluetooth.
I put it on my other system using aorus mobo, the Bluetooth working fine.
Is it because of the internal usb port problem?
If you've swapped boards you'll need to redo your USB Map. This is most likely the issue.
