There was an error returning to Monterey from Sonoma
Ts19971010
I encountered many usage problems after upgrading from Ventura to Sonoma. Now I have reinstalled Monterey, but an error occurred.
I want to know which parts of my current EFI files need to be modified. Initially, I thought the problem was caused by the driver of the wireless network card.
  • OC.zip
As you are using Airportitlwm.kext for your Intel WiFi it could have been this that is causing the kernel panic. As each major release of macOS requires its own version of Airportitlwm.kext. But it is set with MinKernel > 23.0.0 in your config so shouldn't cause a KP in Monterey.
You might want to have a look at updating your AMD Kernel Patches, they are a little out of date.
Sorry but I can't see anything obvious that would cause this KP in your OC folder contents. Only thing that makes no sense to me is your use of SMCSuperIO.kext. I have never used that kext on an AMD system.
Ts19971010
thank you edhawk,i tried times,yeh i finally find out that is SMCAMDProcessor.kext causes this error,even i don't know the reason,just try.
