System Sleep wake Kernel Panic on Ryzentosh Ryzen 5 2600, GT 740, B450 Aorus Elite - Wake transition timed out
tiagoadriao
Hello all,
I'm running Mojave on my Ryzentosh on a B450 Aorus Elite with R5 2600, 16 GB ram and GT 740 2GB.
I can get my hack to sleep, but when it awakes, turns on the fans and power lights but no screen. After 3 minutes it reboot by itself.
I've already mapped the USB ports and even disabled the USB2.0 ports, IO rear and Internal IO using Hackintool.
I got this kernel panic report.
Could anyone help me out?
Thank you in advance.
It's a common AMD issue and I'm afraid there is no real fix for it. However Big Sur seems to have working sleep for alot of people.
tiagoadriao
I've already been there and the issue remains. Is there anyway I could get some info from the kernel panic report? Is it something doable?
You could try the HibernateFixup kext from Acidanthera. Used it to fix wakeup issues in the past.
tiagoadriao
Thanks fot the tip, I'll try that.
tiagoadriao
Still no luck, keeps on kernel panic
