Stuck with macOS installation. Is it even possible?
swisher
Hi everyone!
Here is my config:
ASRock B650 Pro RS
Ryzen 5 7600
GeForce RTX4060 Aero OC
4x16GB Kingston Fury EXPO 6000
Lexar NM760 1TB
Crucial BX500 500GB
2x WD 1TB SSHD
After few days of struggling I stuck with Sonoma installation. When I finally boot macOS installer with NVMe visible as external drive, I erase disk with APFS/GUID setup. After about 25 minutes of installation PC rebooted without any errors and that's it. No boot record, installer from USB is starting again. Installer (I think) created EFI and OS partitions. EFI partition is empty, OS partition has about 15GB files.
I give up and install again W11. Is it even possible to run macOS on my setup? I read there is no chance to run it with RTX card.
Thanks for any reply! And sorry for my english ;)
Your Nvidia GPU isn’t supported in any version of macOS. So no it would be very painful to run macOS if you could install the OS.
You need to replace the Nvidia GPU with a compatible AMD graphics card. See this link for compatible GPU.
