Stuck on IOConsoleUsers: gIOScreenLock
POCTEXHAD3OP
Hello. I have installed mac OS 10.13.3, opencore and Web driver that i installed with Clover. But when changed bootloader to Opencore, and rebooted the PC to enable the driver, the computer freezes on IOConsoleUsers: gIOScreenLock... Before the driver was turned on, the computer was working normally.
The fixes that are described in dortania.github.io did not give results
I attach the EFI folder and last LOG
Processor: AMD Ryzen 5 1400
GPU: Nvidia GeForce GTX 1050ti
  • opencore-2021-12-13-101822.txt
You shouldn't be using -no_compat_check or -igfxmlr. Remove these and confirm it's still an issue. If it is try to disable WhateverGreen.kext
