madvinegar
Hi there. Sonoma 14.3 update is live. Is it safe to update or do we need to make any chages to the kernel patches or config.plist...?
I am on latest OC 0.97.
Thanks!
If the update would actually install for me I'd let you know :ROFLMAO: no amount of SMBios messing or RestricEvents is letting me download the update.
Lorys89
test this version without bootarg revpatch..
  • RestrictEvents.kext.zip
I used the sbvmm boot argument and the update was made available on my ROG STRIX X570 system, after a reboot.
Lorys89
With my kext on sbvmm by default, and with bluetoolfixup kext on, the update is successful
Nope my system is cursed :ROFLMAO:
Full installer also doesn't work :rolleyes:
macOS Sonoma cannot be installed on this computer.
Edit:
Now after a dozen NVRAM resets the update doesn't even appear...
Lorys89
Sip to 00000000, securebootmodel to default?
Yeah. This is the first update that hasn't worked for me. I'll make a USB and install that way at some point I guess.
AMDPUSH
I can download but the install failed...
I don't understand
craighazan
No problems here!, I managed to update mu three builds yesterday, GenMachine, 4700G and 5700X. I used boot-arg 'revpatch=cpuname,pci,sbvmm'. On a side note could someone let TMX86 know that I've banned by CloudFare again, can't access from either my three builds, M1 Air or my iPhone.
Lorys89
AMDPUSH
Bansaku
Just download the installer from the App Store and run that. It will download from the Software Update prefs pane, and give an error when it tries to update, so just exit and run the installer app from the Applications folder. No mods or patches or boot args necessary.
AMDPUSH
Just download the installer from the App Store and run that. No mods or patches or boot args necessary.
are you on OC 096 ?
Bansaku
@Bansaku Downloading from App Store also doesn't work. Told you my system is cursed lol I'll try via USB shortly.
Lorys89
All good now after making a USB installer :D Even changing SMBIOS didn't affect the update or the App running. Same EFI has been used to update Sonoma to where it was. Nothing had changed to stop it working. No changes were made to install from USB either.
Could be an IP issue, as that happened to me not that long ago.
PM me your router IP address and I will ask one of the admins to look at unblocking your IP.
@craighazan Using Chrome works to access the site. It's caused by VPN usage which in this cause is iCloud Private Relay.
