Sonoma 14.2 beta3 booted by legacy OpenCore 0.9.5 in FX-6300 hackintosh
jsl2020
My FX-6300 hackintosh can boot Sonoma 14.2 beta3 & Ventura 13.6.3 by legacy OpenCore 0.9.5 with ProvideCurrentCpuInfo quirk enabled without red screen panic or blank screen issue now after its GPU RX-560 replaced by R9 270 and config.plist modified.
My config-OC-M5A.plist is attached for your reference.
  • config-OC-M5A.plist.zip
Mushie
HI,
Would you please share the guide you followed to get your FX6300 working with Ventura & Sonoma? I am very new to OpenCore and feel a bit over-whelmed. I have successfully followed this guide (which has all the hard work already done) to get Sonoma & Ventura running on AMD 3700X, but would rather have my VMs on a secondary PC that runs FX6300.
Following the same guide on the FX6300 results in "The firmware encountered an unexpected exception. The virtual machine cannot boot." FYI - I have installed and booted MacOS up to Monterey on the FX6300 but, again, would prefer to have Ventura and/or Sonoma on it.
Thanks!
