Same rodeo - different horse.
Tek-Chief
Greetings! I'm a long-time tinkerer. I dabbled in the original Hackintosh scene many years ago. I've worked with macos on VMWare about 5 years ago. Now I'm working to move to the OpenCore ecosystem. At the moment it is a challenge. I'm starting to think my hardware might be overkill for this project. :cry:
leesurone
Similar build here, might find some pointers
Tek-Chief
Thanks! Heading there now. I'm at a stuck point because I can't get past the prohibitory symbol. I've tried all the fixes suggested. At first I though it was because my NVMe was set up in a Raid0 - which appears to be a known issue. I dropped it back to ACHI but no help there.
More likely to be a USB issue, have your tried the USB installation drive in a different port?
Have you tried creating a custom configuration for your USB ports in Windows using USBToolBox tool, linked below.
Kubokun
Glad to hear that someone is using my efi.
First : My motherboard is rev 1.0 refer to 1.2 like your. Maybe some hardwares have been change, after that maybe " patch for gigabyte " doesn't nesesary anymore.
Also as I pointed, you need to change the core counts, smbios info, spoof gpu id to 6600XT
