These properties are either cosmetic or useless, and it wouldn't get stuck here if it was a GPU issue.@PoMpIs,
Try adding this to your device properties and add agdpmod=pikera to the boot-arg. Also enable Whatevergreen.kext (very important step, please don't dismiss it as I have my reasons):
They aren't useless. I've built many hackintoshes to know it works 100% of the time. And yes before you ask I've successfully booted into Monterey and Ventura using the AMD Picasso APU in my Atari VCS build here > https://www.tonymacx86.com/threads/guide-atari-vcs-2020-console.309903/These properties are either cosmetic or useless, and it wouldn't get stuck here if it was a GPU issue.
@ExtremeXT I am assuming you added a SSDT-iGPU-Off.aml? Good going...that's what I was just thinking too!Forgot to attach the EFI, lol, here it is.
@Middleman I also got it working on a few AMD laptops with unsupported iGPUs and didn't need any of the properties
Try enabling DevirtualizeMmio.@ExtremeXT
It hasn't worked..
It restarts instantly when trying to start Ventura and in Monterey it doesn't go from here:
It is that the bios of this motherboard is quite bad, it has bugs... it is a BETA bios
On all motherboards, Gigabyte, MSI, Asrock, iGPU can be disabled...
I have tried in a thousand ways, even with this latest EFI, I have tried to disable Resize bar and virtualization in bios, but nothing changes
@Shaneee I think we need a new kernel patch...Tried..
The following happens:
Monterey:
Ventura:
I attach the EFI with the modifications
@PoMpIs,
They messed it up on accident when removing the SMBIOS data, this one should work. (I just fixed the error, no other changes.)When I tried reviewing the config.plist in your EFI, from post #51, it shows the following error in ProperTree,
View attachment 7432 Error message in ProperTree (latest version)
@PoMpIs Looks like it's a TSC issue. https://github.com/apple-oss-distri...3dfdf34262bb0042026747cc/osfmk/i386/mp.c#L904
Can you try adding this kext? https://github.com/naveenkrdy/AmdTscSync
Make sure to change the IOCPUNumber to 31 in Info.plist.
If its still not working, try to add TSC_sync_magin=0 to boot-args.
Maybe set TscSyncTimeout to 500000 too.
- ExtremeXT
