- Joined
- Mar 20, 2024
- Messages
- 4
r5-7535hs,Using SSDT to disable graphics cards
If using mmiowhitelist and enabling DevirtualiseMmio, it will stuck on the [EBILOG:EXITBS:START](First picture)
If i don't use mmiowhitelist and only enable DevirtualiseMmio, it will stuck on please go to,but the display resolution has changed to 2k.(second picture)
The BIOS manufacturer for my mainboard should be AMI, but my laptop brand vendor has streamlined the BIOS to the point where I cannot disable fast boot and CSM.Is there any way to achieve the same effect as disabling fast boot and CSM by modifying the config.plist file?
If possible, could you provide some help or ideas? Thank you everyone.
