OsxAptioFixDrv issue after installed on disk
drxvmrz
Hello!I have some problems after installing the system on HDD.
When i boot the PC there are clover boot screen with ability to choose "Boot macOS install from (my disk)" (fig. 1)
After this i have an issue fig.2. At the first time before installing on disk i've been on issue from this post "click".
But that time it was disappeared by itself after waiting a little bit time. And this time i was waiting for 30 mins and there was not any effect...
System:
CPU: FX-4300
GPU: GTX 650 (1 Gb)
Motherboard: Biostar A78LR-M3S
RAM: 16 Gb DDR3
Post a copy of your Clover EFI folder so we can see what you are using on this Legacy Motherboard.
Posting screen images doesn't really tell us much.
Did you try booting the system from the left-hand 'Mac OS' icon?
What does that do?
Which version of Clover are you using?
System:
CPU: FX-4300
GPU: GTX 650 (1 Gb)
RAM: 16 Gb DDR3
Clover is obsolete and not supported anymore, using OpenCore is strongly recommended.
