OC 094 ok for Ventura 13.5 ?
AMDPUSH
I said that, because i have unfortunately erased my 093 OC working EFI for Ventura13.5 and now i am unable to load it with 094. I can run OC boot canopy pick the disk, but when it comes to the loading bar with the apple logo, it stops and i get stuck. I used to to update eassily for a while now, but this time i 'am confused.
leesurone
Add the -v boot argument to your config.plist and then take a picture of where it stops an then upload it. That way there is some additional information available to help trouble shoot your issue.
RyzeCooker
Unrelated, but odd... I don't get offered 13.5 at all, even though it's been out for a while it seems. EDIT Got offered 13.5 after a billion refreshes, but then I read about Location Services issues, so I'll wait for 13.5.1 ;)
AMDPUSH
Finally i made a new fresh install and everything is ok. perphaps OC can find the disk or with the multiupdate, even if created a new USB key with the latest version of ventura. Who knows. i just remembered, i have erased the EFI and copy the new one (OC 094) from working Monterey disk. This time i made all the tuning on the USB key, i read somewhere that can be an issue. OC 094 is ok with Ventura 13.5
AMDPUSH
I just tried to fill my wifi code and Ventura rebooted instantanously, but the Wifi wasn't working, and i put the code again and the same thing. reboot and even switch off Opencore booting directly to W10. I think there something wrong with kext for native WIFI of the motherboard.
leesurone
Are you using the correct version of the Airportitlwm.kext for Ventura? There is a specific kext for each version of the OS, if you try to use the Monterey release on Ventura it will cause panic at boot.
AMDPUSH
yes i put the stable one for Ventura, not the latest. Finally i removed it from the EFI
joostiphone
Even within Sonoma there are different versions now:
RyzeCooker
Noticed 13.5.1 dropped, fixing the Location Services issue.
