No Realtek Devices Shown in DPCIManager
RegDogg
Hello everyone!
I have recently installed macOS Mojave and still have 1 issue, I first noticed my Realtek Audio (ALC1220) isn't working, then my Ethernet. I have both AppleALC.kext and RealtekRTL8111.kext in my EFI/OC/Kexts, and in my OpenCore config.plist, they aren't even show in IORegistryExplorer, which I find is weird, because it is shown in Windows Device Manager, Could it be my BIOS settings? Or even a mistake in my OpenCore?
Someone please respond ASAP. Thank you!
Edit: My Hackintosh Specs are in my signature
Check they have been entered into your config correctly. Search your IOReg for en0 I've never seen it not show in the IOReg before. Also disable the Serial port in your BIOS if you haven't already. I used to have that board and it helps.
RegDogg
They have, Kexts has AppleALC, and RealtekRTL8111.kext configured properly.
I'm using a WiFi card for now (Shows up as en0), but can't seem to find my Realtek GBE device in DPCIMangaer, nor IORegistryExplorer
Trying that rn, will get back to you
BTW Realtek Audio is now working fine, I ditched the audio section of my UEFI, and used the "alcid=" boot arg
