My first Amd OS X, help help
Scoundrel
Hey guys, I just start to build my Amd Os X but i will need some help and tips to do it. I made the boot usb with the Catalina OS backupfiles as the instruction on the Install Guide says and I try with some of EFIs but I am stuck on the OpenCore window I think there is a problem with the EFI at first and dont know how to fix it and make the proper EFI for my configuration. So if someone have some tips and advices I will be happy to read it and continue trying until its WORKS :D chears
Motherboard- Gigabyte GA-AB350M-DS3H
Processor- AMD Ryzen 5 2600 6x3,4 GHz (3,9GHz)
Ram- Crucial Ballistix DDR4 32GB (2x16) 2400 UDIMM
Video- AMD Radeon Sapphire Nitro+ RX 480 8Gb GDDR5
PS- Cooler Master V750 / Compact 750W 80 PLUS Gold PSU ATX
Case - CoolerMaster MasterBox Q300L Midi ATX
SSD- Crucial BX500 240gb
HDD- WD Blue 1Tb
So my question is can you give me some tips how to install it on my Pc?
