Monterey Works, but Ventura simply won't install (get's stuck)
anaplian
Hi there,
I have fully working and stable Monterey build but I cannot get Ventura to install. It hangs on install at the Apple Logo with no progress bar from the log:
107:033 00:096 AAPL: #[EB.LD.OFS|OPEN!] Err(0xE) <"usr\\standalone\\OS.dmg.root_hash">
107:129 00:095 AAPL: #[EB.RH.LRH|P!] ope
107:850 00:721 AAPL: #[EB.BST.FBS|!] Err(0xE) <- EB.RH.LRH
My Build:
Motherboard: ASUS TUF GAM. B550M-PLUS WIFI
Processor: AMD Ryzen 7 3700X Processor
RAM: Corsair Vengeance RGB PRO 32GB (4 x 8 GB) DDR4 3200 MHz C16 XMP 2.0 Enthusiast
Graphics Card: AMD Radeon RX 6800 XT 16 GB
Attached are my EFI and the errolog I get when I try and install Ventura.
With thanks
Daniel
  • opencore-2023-09-02-100741.txt
Try this revised EFI folder it is based on my Asus TUF Gaming B550 Plus (WiFi) & Ryzen 7 3800XT system running macOS Ventura.
I have:
  • Replaced the SSDT-EC-USBX-Desktop.aml table with SSDT-EC-USBX-AMD.aml table.
  • Updated the AMD Kernel patches to the latest release (this was probably the main cause of your kernel panic).
  • Removed a number of unnecessary Drivers and Tools.
Hope this helps.
