Solved I need help sleeping on the b550m aorus pro ax motherboard.
moka
3D1883FC-9502-4935-87B7-30233AC354A0.pngComputer configuration:
Motherboard:Gigabyte B550M AORUS PRO AX
CPU: AMD R5 5600x
Memory:Crucial 8Gx2 3600MHz
dGPU:AMD Radeon RX 5700XT
NVMe:A2000(Macintosh)/ sn770 / sn720
Problem description:
I turned off the WLAN to wake up in bios. Now my sleep can only be less than 10 minutes, and the power will be turned off in more than 10 minutes. The host is in an unknown state. As shown in the video, the light on the keyboard is not on, the shutdown button and the restart button do not work. You need to turn off the power switch behind the chassis before you can restart or wake up.
video:
Sleep log after 10 minutes:
Lorys89
use ssdt for disable gpp0
Solution
moka
Lorys89
  • SSDT-DISABLE-GPP0.zip
