You will need to use the nvda_drv_vrl=1 boot argument with your GPU when running macOS.
Your GPU is only supported with the latest release of the Nvidia Web Drivers. You will not be able to update to a newer version of macOS without first swapping your NVIDIA GPU for a compatible AMD GPU.
Latest Nvidia Drivers for High Sierra can be downloaded from this post over at Tonymacx86:
