Help - Ryzen 9 7900X / X670E System not booting into macOS setup!
htt37ps
Hi! I built a new PC and now i want to install Hackintosh. I have a Aorus X670E Mainboard with Ryzen 9 7900X and 32GB's of Ram. It's my very first time of trying to install Hackintosh to a AMD system. Here is my EFI:
Problem is when I'm trying to boot, I see [EB|#LOG:EXITBS:START].
mariettosun
if it could start in this way it would be a miracle
you miss virtualSMC kext
EDIT
you miss also MMIO part in your config
mariettosun
can u fix it for me or tell me how to fix it? thanks!
I advice to take an ACPI fix from here and you can also use his MMIO part
as soon I come back to my pc I will try to help better, but you have to read a bit from your own
mariettosun
if you like backup yours and try this one
if doesn't boot post Sysreport and debug log you can find in your USB or on your EFI partition
  • EFI-2.zip
htt37ps
Hi again! I can't see the macOS installer or Windows Bootloader in OpenCore menu.
Did you try pressing space? Is ScanPolicy set to 0? Do you have an HFS EFI Driver?
htt37ps
It Worked!!!!
PrichA
Hi
It Worked!!!!
Hi,
Are all your hardware working?
PCIe
Bluetooth
Wifi
Audio
I'm having a challenge with mine. And, does your hard drive boot into OSX on it's own or do you have to have in the installer USB?
Thank you,
