help OC : confirguration failed
xkeithyx
i want to trying installing mac os high sierra on amd AMD A8-7650K with nvidia gt220, whent it boots to usb and it shows OC : Confirguration failed
I've been changing the config.plist confirguration and still failed
please help on this config.plit
Which motherboard are you using?
Which version of OpenCore are you using?
Are you using the latest version of the AMD Kernel Patches?
Can you post a copy of the kernel panic (verbose text)?
Can you explain what you mean by configuration failed, i.e. does it reboot, post some verbose text and stall or does it black screen?
