Help for AMD Ryzen 7 5800H lenovo legion 5 15ach6 laptop MacOs
mmsalmalki
plz help me for create EFI or If you have EFI File my spce
CPU: AMD Ryzen 7 5800H with 8 GB radeon Graphics
Ram: 16 GB Ram
HDD: 500 GB SSD NVME
GPU: Nvidia Geforce RTX 3 3050 Ti
Have a look at the links in this post.
See if the EFI linked helps.
mmsalmalki
thank you
Edhawk thank you for reply i will try the EFI files but how to editing bios please fix this i cant install montery latest version​
AMD Bios settings shown in screenshot below.
Screenshot 2024-02-26 at 18.26.54.png AMD Bios Settings for running macOS
mmsalmalki
Edhawk thank you for reply but it appering to kernel panic Amdcpusupport : : start got CPUID : 10 68747541 444D4163 69746E65​
These ACPI errors are visible in the screen image you posted above.
Your EFI is either lacking an SSDT (SSDT:CB-01), is calling out devices that don't exist (\_SB.PCI0.PB2) or has SSDT's that duplicate device naming (SRFZ).
So I would recommend looking in to the SSDT's in your /EFI/OC/ACPI folder to discover which SSDT's are causing these errors.
Post a copy of the EFI you are currently using and I will have a look to see if I can find the cause of these errors.
Nothing attached to either of your last two posts.
You need to compress/Zip the EFI folder and attach it to a post, using the 'AttachFiles' button.
mmsalmalki
Ram: 16 GB Ram
Guantanamera
Ram: 16 GB Ram
Try this one, it helped me install Sonoma, it works pretty well, I think everything...
