Catalina is Convertable To APFS Error
portekizli
Hi, there.
İnstallation with opencore 0.5.7,
Catalina gives the setup file isConvertableToAPFS error and suddenly restarts and setup error while copying the files. Is there any help for solution?
"ROM Features returned: 4256165990
isConvertableToAPFS: was called on disk0s4, an APFS disk.
osinstallersetupd[648]: disk24 is not convertible to APFS"
MyKext: AppleALC, AppleMCEReporterDisabler, Lilu, NVMeFix, SmallTreeIntel82576, VirtualSMC, WhateverGreen.
config.plist file is validate on https://opencore.slowgeek.com/ (fix all problem)
portekizli
  • Installer Log 4-May-2020.txt
Try to format the disk to APFS before installing.
portekizli
I've tried. One of the man I saw in a forum solved it by changing the config.plist. but I couldn't reach him. my config.plist has an error but i couldn't find where. I'm missing something. but what?
If there is an error in your config the sanity changer should show it. What SMBios do you have set?
portekizli
Yes. I check on Sanity Check (all fix). iMacPro1,1
Try using iMac14,2 for now.
portekizli
  • Installer Log 5-May-2020.txt
