I success to install Ventura after several days of research
How to success (from PC. windows 11)
- Torrent Raw image ventura v 13.6
- Create Boot USB from raw image by belena ethcer. I try install it from recovery mode (Youtube tell, not success)
- https://github.com/daliansky/minisforum-UM560XT-Hackintosh
Use mini tools partition for delete and format EFI drive of USB (see youtube)
- copy EFI of UM560 to EFI drive of USB
create our DSDT for ACPI, by SSDT Time - dsdt.aml, ssdt-cpur.aml, ssdt-ec.aml, ssdt-usb-reset.aml, ssdt-usbx.aml (see youtube)
copy all these files to to ACPI folder of usb drive
Modify config.plist of usb drive by OCAT-Win64
- modity config.pllist
- add all *.aml files to acpi tab
- Set SMBIOS. iMac20,1 and generate SMBIOS. - overide
- add boot arg. -v. for verbos mode (need to monitor install process)
use Mini tool partition to change type of usb to GPT drive
- set bios Ram of iGPU. 4GB, No secure boot, CPU. 45 watts
- Boot from USB drive
- Wait patience. ( slow process some times, but work, some time I think it is not success (wait for 10 minutes , but continue to install ,yes partience)
- It is china version of ventura. (My son can read china language 5555)
- see youtube for detail of install
- Two monitors, work with USB type port and HDMI
- iGPU, good by Nootered. (Thank you very much for your hard work for AMD APU)
- Chrome browser. , switch. off hardware accelator by nootered guide
- Sound work
- Lan port Realteck 8xxx work
- I install two. m.2 2280 (one for windows 11, one for Ventura)
- You can insert m.2 2280 to. m2 2230 of mini pc. (work, enough room)
- Only not work. realtek wifi card, must replace by intel card ??
Thank you everybody in youtube and website for guides (especially EFI from UM560 XT guide)
Suchart
Bangkok
Thailand
