AMD ryzen built - first Hackintosh build - need help
chohoy
Hello Good people :)
I am aiming to build my first hackintosh on which I plan to do some photo/video editing and also occasionally boot into Windows to game. attached is the link to the PC part picker list I created, please take a look at it and let me know if it would be a good config for a hackintosh.
https://ca.pcpartpicker.com/list/npsnrV
Thanks in advance! :)
Should be just fine (y)
Mentioning photo/video editing, just be aware that Adobe products do not work out of the box on AMD systems.
agent2
I think you'll be just fine going with one M.2 SSD to partition and put both OSes onto it. Just take the money you save and get a better motherboard (the one in the list is overpriced because it's out of stock except for Amazon) and downgrade to the 3600 and get a better CPU cooler. But otherwise you're set!
Here are some alternatives:
PCPartPicker Part List: https://ca.pcpartpicker.com/list/3fWmvW
PCPartPicker Part List: https://ca.pcpartpicker.com/list/LQkqgJ
PCPartPicker Part List: https://ca.pcpartpicker.com/list/zHCCk6
