2 EFI After upgrading to OC 0.8.8
Danish297
Hi All,
Any idea, why I'm getting two EFI option in OC boot menu after upgrading to 0.8.8.
How can I remove 1 extra EFI option now?
Pabo
Hi All,
Hi, I want to ask you if you could give me your EFI. I have the same motherboard that I do not use but I would like to put it into operation and try. Thank you so much
Danish297
Sure, attaching my EFI. Please update PlatformInfo section in config.plist file as required.
  • EFI_088_x570.zip
Pabo
thank you very much
Pabo
Hi All,
After clean installation everything is OK, I have only one option EFI. Thanks for the EFI-tested and it works fine. You use the native wifi/bluetott or fenvi T919? Thx
Danish297
Are both of those disks internal?
Have you tried resetting NVRAM?
I have done dual booting in single Disk.
YES, tried resetting NVRAM, still same issue.
Danish297
native wifi/Bluetooth
EFI partitions are set differently in OC 0.8.8. This is a change from previous releases. Have a read of this guide over at Tonymacx86
This all relates to ‘contentVisability’.
AMDPUSH
Try this one. You 'll need to fill Platform info, adjust the boot argument to your graphic card and check >Booter and the ressources to put your custom blue boot screen. Be sure your bios is updated. rebuild the USBMap Kext . reset nvram. make dummy USB key.
  • EFI AORUS MASTER V1.2 OC88.zip
Danish297
Got cause of getting multiple EFI options in my OC Boot menu.
As I have multiple HDD, and NVMe drives. Seem each HDD formatted with GUID FS creates an extra EFI partition.
so when I formatted my HDD with MBR simple partition, my extra EFI was gone.
@Edhawk : Thanks for showing this feature added in OC 0.8.8, Now my OC boot menu look better than B4.
@Others: thanks for taking some time to see my issue.
