2.5G Ethernet Card (Intel or Realtek?)
tristan
I am planning to add a PCIe Ethernet card 2.5G, and I don´t know which card choose between Intel i225V or i226V and Realtek RTL8125BG.
Do you have any xperience with each, kext, issues,... or which is better ?
And also consider a 10G card X540-T2?
Thank you very much for your comments!!
leesurone
Either the intel or Realtek cards should work, you might find the Realtek card easier to configure. In the end I think it's pretty much a wash on performance. A far as the 10G card I don't believe the intel x549-T2 card is supported.
tristan
Thanks! usually I copy a large files between the computer and a server with Unraid, this is the reason for add a ethernet card. (nextcloud, jellyfin, backup, raw photos...)
I found this link for a 10G card...
leesurone
Good luck
leesurone
I would recommend an Aquantia based card instead, lots more documented resources going that route. One example below.
https://www.tonymacx86.com/threads/...t-with-aqc113c-chip-for-macos-ventura.325087/
