hi! can i insstall mac os high sierra on AMD A8-7650K?? please help
xkeithyx
can i install mac os high sierra or older on this amd proccesor?? helpp
Not if you plan to use the integrated graphics.
You would need to disable the R7 IGPU and use a discrete GPU for all graphics processes.
You would need to follow the 15H/16H (Bulldozer) OC guide.
The oldest version of macOS you can run using the native/Vanilla AMD guide is High Sierra.
xkeithyx
if I use igpu is it possible? i dont have any like gpu or discrete gpu
Some people have reported successfully installing macOS on AMD system with just an AMD IGPU. I don’t know how well they work I don’t think they work with graphics acceleration.
It is not something I have tried to do. I assume without WhateverRed the OS will be painful to use, lots of graphical artefacts and glitches.
