Big Sur 11.6 Fully Working AMD
Theshadowfang
Ryzen 7 2700x 50 year
Hardware:
  • CPU: Ryzen 2700x
  • GPU: Asus Strix Vega 64
  • RAM: G.Skill Trident 32GB 3200
  • Motherboard/Laptop model: Asus Rog Crosshair Vii Hero X470
  • Audio Codec: ROG SupremeFX8-Channel High Definition Audio CODEC S1220
  • Ethernet Card: IntelĀ® I211-AT, 1 x Gigabit LAN Controller(s)
  • BT Card: Asus USB-BT400 Adapter
  • What guide/tool followed: https://dortania.github.io/OpenCore-Install-Guide/
  • What part I got an issue with: Hardware Acceleration wasn't working, used SMBios MacPro6,1 for install and changed to iMacPro1,1 and Hardware Acceleration is fully supported and tested.
  • What files/config I am using:
  • OpenCore-0.7.3-DEBUG for install updated to RELEASE
  • HfsPlus.efi
  • OpenCanopy.efi - nice to have a boot GUI - https://dortania.github.io/OpenCore-Post-Install/cosmetic/gui.html#setting-up-opencore-s-gui
AMD_Vanilla-master - Please follow the guide on Vanilla before downloading or patches will not work.
  • GenSMBIOS
  • MountEFi
  • ProperTree
  • PyVega - boost clock / fix fan speed, I'm liquid cooled.
  • SSDTTime - No Luck with prebuilt, Created SSDT-EC/USBX
  • VDADecoderChecker
  • Kext:
AMDRyzenCPUPowerManagement
AppleALC
AppleMCEReporterDisabler
Lilu
SmallTree-Intel-211-AT-PCIe-GBE
SMCAMDProcessor
VirtualSMC
WhateverGreen
Nice build.
Btw, you could get a free GPU upgrade, the Vega 64 sell for around the same as a 5700 XT currently.
Hardware:
  • CPU: Ryzen 2700x
  • HfsPlus.efi
  • GenSMBIOS
  • MountEFi
  • ProperTree
  • VDADecoderChecker
  • Kext:
AppleALC
Lilu
SMCAMDProcessor
slope game
VirtualSMC
WhateverGreen
Thanks for posting a success!
Hello, is your computer configured the same as mine? Can you share your EFI with me? thank you
CPU: Ryzen 5 3600X
Motherboard: Asus ROG CROSSHAIR VII HERO (WI-FI)
RAM: 16GB DDR4 3200MHz
Graphics: SAPPHIRE Radeon R7 240
HDD: SAMSUNG 970EVO 500GB
Have you tested your Ethernet (Intel I221-AT) performance? I only have 100Mbit/sec performance on Gigabite Network with this built-in ethernet controller.
I can only get about 90Mbps download/upload speed over my 300Mbps fiber internet in Ryzentosh, found out my ethernet is capped at 100Mbit/s connection in Mac. Still looking for solution or fix...
Have you tried changing the settings for the Ethernet controller in System Preferences > Network > 'Ethernet controller' -
Screenshot 2022-01-07 at 14.12.27.png System Preferences > Network pane
Then select the Advanced button and navigate to the Hardware tab. Change this from Automatic to Manual, insert the correct options as shown below:
Screenshot 2022-01-07 at 14.12.02.png Advance > Hardware tab - manual ethernet port settings.
Don't forget to select the 'Apply' button after you exit the Advanced section. Otherwise the settings won't stick.
View attachment 4724 System Preferences > Network pane
View attachment 4725 Advance > Hardware tab - manual ethernet port settings.
thanks for the reply Edhawk, I tried to change to Manual settings, I don't have "Energry efficient" option as seen in your picture, and it didn't work out. Speed still capped at 100Mbits/sec.
Screen Shot 2022-01-08 at 10.47.05 AM.pngScreen Shot 2022-01-08 at 10.41.14 AM.png
Hardware:
  • CPU: Ryzen 2700x
  • HfsPlus.efi
  • GenSMBIOS
  • MountEFi
  • ProperTree
  • VDADecoderChecker
  • Kext slope game
I need it. Thank you very much.
Thanks for sharing this project! It's always impressive to see a fully working AMD setup running Big Sur 11.6 smoothly. Guides and success stories like this are incredibly helpful for users interested in Hackintosh builds and system optimization. I enjoy exploring different tech projects, from custom macOS installations to classic gaming experiences like fnaf 1. Great work, and thanks for documenting the process!
