- Joined
- Mar 13, 2020
- Messages
- 2,190
macOS Monterey
The latest version of macOS, Monterey, is now available to download according to Apple. The software has been available in public beta for several months, but today’s release means Apple thinks the software is ready for everyday use.
As is tradition, Apple announced its latest version of macOS at WWDC in June. New features include the ability to set Macs as an AirPlay target to play content from iPhones and iPads, as well as Shortcuts, Apple’s iOS automation software. There have also been improvements made to FaceTime, as well as a new Quick Note feature. For a full rundown of what’s on the way, check out our preview from July, as well as Apple’s own feature list.
Unfortunately, some of Monterey’s biggest new additions, Universal Control and SharePlay, don’t seem to be available at launch. Apple notes that both features will be available “later this fall.”
Universal Control allows files to be dragged and dropped between several different machines, as Apple’s Craig Federighi demonstrated at WWDC. It also will let you control multiple Apple devices including Macs, MacBooks, and iPads, with the same mouse and keyboard.
SharePlay will enable shared experiences of music, TV shows, movies, and more while connected over FaceTime. Once it’s available, Apple says you can use the feature with Apple Music, Apple TV+ and unnamed “popular third-party services.”
It’s better news when it comes to Safari’s redesign, which by default now uses a more traditional interface rather than the controversial new tab design introduced at WWDC. Early users complained that, among other things, the changes made it far too difficult to work out which tab was currently active.
The full list of Macs that can run Monterey can be found below:
- iMac (late 2015 and later)
- iMac Pro (2017 and later)
- Mac Pro (late 2013 and later)
- Mac Mini (late 2014 and later)
- MacBook Pro (early 2015 and later)
- MacBook Air (early 2015 and later)
- MacBook (early 2016 and later)
To install Monterey, go to System Preferences > Software Update (or search “Software Update” in Spotlight). If Monterey shows up as an available install, you can then click the upgrade button to begin the install process. If it doesn’t show up, you may need to check back in later, as it continues to roll out.
Hackintosh Notes:
- As with the beta version make sure you've got OpenCore 0.7.4 as older versions had issues with SecureBootModel not working.
- Ensure you've got the latest AMD Vanilla patches and you've taken a look at the ReadMe. They won't work unless you make some changes
- If you rely on SmallTree for LAN you're out of luck just now until something is created to replace it.
- Some MSI board will not work on Monterey with newer BIOS revisions. If you've got a MSI board try booting a USB installer rather than an update. If the installer boots install to a second partition/drive to test stability.
