Alienware R10 Install Issues
Dizzit
Upload your EFI and I'll double check it.
I am also struggling. I posted my ISO via google drive below if you don't mind having a look.
I am running a 5950X with RX 6800xt on an Alienware R10. One thing I am struggling with is knowing whether I have a B550 of X570 MB. I read multiple forums that suggested CPUiNFO and HwInfo is displaying the incorrect details. They both state I have X570, but again, I read that this is a mistake and I actually have B550.
Anyhoo, again... I posted an iso image of my USB I am trying to use below. Any help is greatly appreciated.
Also, I am including pictures of the different errors I revived with CPU PLUG and without, with Mojave, BigSur, Catalina, etc. I have bee trying different combinations to try and strong arm this into working. :-/
Your EFI isn't public. Also according to DELL it's a B550a.
Dizzit
I attached it here for your use. It can also be accessed via my google drive. Thanks in advance.
Dizzit
I reapplied the patch and I set the frequencies manually to no avail. Still stuck on this error.
Try this. If it does the same remove the SSDT-CPUR.aml entry from the config and try again.
