- Joined
- Mar 13, 2020
- Messages
- 2,186
macOS Monterey 12.x AMD Patches
Here we are people. The macOS Monterey AMD Patches for OpenCore. They currently work great but as with any Apple update they may break so keep that in mind.
There are some things you should know first,
- Only Developer Beta 1 is supported ( 12A5248p )
- Patches for Beta versions are provided but no support is given until the OS is released.
- Try these patches at your own risk and always have a backup EFI to boot.
- Always make sure your kexts and if required OpenCore version is updated first.
- Make a backup! This should always be the case when installing beta software.
- Be patient with patch updates.
You can download the installer image with gibMacOS and the command to create a USB is on the Github Repo Readme. As mentioned above as it's a beta release, we won't offer support for those willing to install macOS 12.0 on their system. Once Apple have released it publicly then we will provide support.
Github Repo: https://github.com/AMD-OSX/AMD_Vanilla
As always, enjoy your AMD Hack and have fun.
Thanks,
