#54121
I just live-updated Catalina 10.15.2 to 15.3 on OpenCore (0.5.4) and it worked. Here's how it went:
- got update notification in System Preferences
- loaded the update and began installation --> first reboot
- OpenCore automatically selected "macOS Installer" --> booted to Apple logo --> immediate reboot
- OpenCore did NOT select "macOS Installer", I had to manually select it! --> booted to Apple logo --> installation began
- third reboot --> OpenCore automatically selected the system disk --> booted to Apple logo --> installation continued
- picture froze up without errors at "2 minutes left" with progress bar at ~85%
- I let it sit for 10 minutes and hard rebooted --> OpenCore booted system disk --> macOS complained about not shutting down
- update was successful!
So you have to watch out for two issues:
1) select "macOS Installer" in OpenCore if it's visible (had to do it twice)
2) your install may freeze up with 2 minutes to go --> let it sit for a while and reboot your system manually
iGPU liked this
#54129
Thanks, I just did it as well. Mine didn't freeze. I do have the oddness that my installer likes to switch to Russian for some reason. Had that on my initial install as well.
But mine didn't freeze. After two reboots where I did have to choose the installer the 2nd time like you said, it came up after a couple of minutes.
MadMax1998 liked this
#54132
I just did the update to 10.15.3 with OpenCore 0.5.4. Everything went smooth.
I didn't have to select the installer or something. Everything went through without any freeze.
#54137
Also upd2date without problems
When't Full Automatic
#54146
Nice going guys, thanks for confirming the freeze is not common. That's good! :thumbup:
#54282
lazyusername wrote:Anyone have a guide for Clover?
Because I am NOT switching to OpenCore.
1: Why not?
2: You can't go past 10.15.1 with Clover.
Hi all! I'm trying to install Catalina 10.15.3 but[…]
So quick update. I swapped out the WiFi card on […]
Recently, I need to use video camera a lot to in o[…]
Hi Guys So after much more time than I thought, I […]
