#52503
*google translate
Hello. Following the AMD Vanilla guide in the gibmacos program, you need to download a Recovery file that weighs 500 MB, I downloaded it and when I started the MacOS installation, I realized that to install MacOS I need Internet access via Ethernet to start the installation.
Now in gibmacos I downloaded the full installation (7 GB), what should I write to the flash drive in makeinstall so that I can install MacOS normally and without the Internet?
#52509
neoney wrote: Wed Nov 20, 2019 9:05 am Check my reply under https://forum.amd-osx.com/viewtopic.php?p=52506#p52506 out
It is working for my Realtek8111 ethernet card, thanks
There is no XXXX-ROOT in SmallTreeIntel82576.kext, this method is not working for Intel i211 chipset
Yes it's possible. I don't recommend using the sam[…]
Thanks for your post! I'm looking into replacing a[…]
Hello! I've been trying to get my OpenCore configu[…]
Fail. Not worked for nvidia gtx 1070
