by: jagger
#51461
Wasn't hard at all. The key was the AppleMCEReporterDisabler.kext
– ASRock B450M Pro4
– Ryzen 2700X (3.9GHz OC)
– MSI GamingX RX 480 8GB
Kexts used:
– AppleMCEReporterDisabler.kext
– Lilu.kext
– NullCPUPowerManagement.kext
– RealtekRTL8111.kext
– VirtualSMC.kext
– WhateverGreen.kext
Not working: onboard USB 2.0, 3.0 ports work. Haven't tested audio, I use USB amps that work OOB.
by: Treasley
#51467
Can’t get past the MacOS utilizes screen where you “reinstall Mac OS”. It gives me an internet connection is required pop up - 100% connected to the internet and 100% used this method to do a perfect Mojave Hackintosh- same kexts and all. The only think I changed was the 17h config file and the Catalina install files.
Via
https://vanilla.amd-osx.com/
by: Mudza
#51479
Treasley wrote:Can’t get past the MacOS utilizes screen where you “reinstall Mac OS”. It gives me an internet connection is required pop up - 100% connected to the internet and 100% used this method to do a perfect Mojave Hackintosh- same kexts and all. The only think I changed was the 17h config file and the Catalina install files.
Via
what clover version do you use? before i have same problem with you, but I switch to older version clover and the error message gone (clover version 5091), maybe this trick can work also for your problem
by: Treasley
#51490
@Mudza, I'll be honest, i'm not entirely sure how to update or downgrade clover. I'm using the vanilla guide where it has you download github tools that automatically puts clover and MACOS on the usb. Any advice on how to do that and use 5091?
by: Sundhar88
#51501
Treasley wrote: Wed Oct 09, 2019 4:20 pm @Mudza, I'll be honest, i'm not entirely sure how to update or downgrade clover. I'm using the vanilla guide where it has you download github tools that automatically puts clover and MACOS on the usb. Any advice on how to do that and use 5091?
Open Clover Configurator
On the left pane look for install/upgrade clover
Click check now
At the right bottom you'll find current booted version of clover
Here's recommended clover for Catalina (worked for me)
https://github.com/Dids/clover-builder/ ... r5092.pkg
It's a simple fix. Open your network kext and edit[…]
Hi gm0rk, I have the same mainboard as you, an AS[…]
Use this modified RTL8111 for LAN, https://www.d[…]
alright i'll do that thanks Post Merged hello […]
