#51219
Hi everyone !
First sorry if my English is bad, i'm from France and i don't speak english so well.
I've done fresh vanilla install of Mojave 10.14.6 by following the tutorial. Everything works perfectly, USB, Sound, Graphics acceleration, Network ect...
I have a Ryzen 5 1600 @ 3,2Ghz , 16Go of DDR4 2666Mhz, My motherboard is an ASUS Prime B350 Plus, and my Graphic card a Sapphire Vega 56 Pulse.
I have a dual boot with Windows 10, i use mainly WIndows for gaming and MacOS for music production with Logic Pro X.
Thanks to the staff of AMD OS X for their tutorials and forum.
dragonx41 liked this
It's a simple fix. Open your network kext and edit[…]
Hi gm0rk, I have the same mainboard as you, an AS[…]
Use this modified RTL8111 for LAN, https://www.d[…]
alright i'll do that thanks Post Merged hello […]
