by: hugodligo
#50648
Hi, everybody!
I installed 10.13.6 (17G65) following the vanilla tutorial and nVidia Web Drivers (387.10.10.10.40.105) successfully on my machine. Then I installed update 2019-004 (17G8030) and nVidia Web Drivers (387.10.10.10.40.130).
Even before the update, I'm experiencing two problems: slow file system performance (there's a delay when opening folders and files the first time after boot, then it seems to be cached. it happens even when using ls on the terminal) and delays and lags on the GUI (menus delay to appear, pages on safari slow to render, lags on typing, cursor shows loading almost every minute and etc).
Is there something I missed to configure? Is it a general problem?
Thanks!
by: appy79
#50649
attach config.plist (hide your serial number from SMBIOS section). Also the name of kexts which you are using.
#50650
<?xml version="1.0" encoding="UTF-8"?>
<!DOCTYPE plist PUBLIC "-//Apple//DTD PLIST 1.0//EN" "http://www.apple.com/DTDs/PropertyList-1.0.dtd">
<plist version="1.0">
<dict>
	<key>ACPI</key>
	<dict>
		<key>DSDT</key>
		<dict>
			<key>Fixes</key>
			<dict>
				<key>AddDTGP</key>
				<false/>
				<key>AddHDMI</key>
				<false/>
				<key>DeleteUnused</key>
				<false/>
				<key>FakeLPC</key>
				<false/>
				<key>FixAirport</key>
				<false/>
				<key>FixDisplay</key>
				<false/>
				<key>FixHDA</key>
				<false/>
				<key>FixHPET</key>
				<false/>
				<key>FixLAN</key>
				<false/>
				<key>FixRTC</key>
				<false/>
				<key>FixShutdown</key>
				<true/>
				<key>FixUSB</key>
				<false/>
			</dict>
			<key>Name</key>
			<string>DSDT.aml</string>
		</dict>
		<key>HaltEnabler</key>
		<true/>
		<key>SSDT</key>
		<dict>
			<key>EnableC6</key>
			<false/>
			<key>Generate</key>
			<dict>
				<key>CStates</key>
				<false/>
				<key>PStates</key>
				<false/>
			</dict>
		</dict>
	</dict>
	<key>Boot</key>
	<dict>
		<key>Arguments</key>
		<string>-v npci=0x2000</string>
		<key>DefaultLoader</key>
		<string>boot.efi</string>
		<key>DefaultVolume</key>
		<string>LastBootedVolume</string>
		<key>Legacy</key>
		<string>PBR</string>
		<key>NeverHibernate</key>
		<true/>
		<key>Timeout</key>
		<integer>-1</integer>
	</dict>
	<key>BootGraphics</key>
	<dict>
		<key>EFILoginHiDPI</key>
		<integer>1</integer>
		<key>UIScale</key>
	</dict>
	<key>CPU</key>
	<dict>
		<key>C6</key>
		<false/>
		<key>UseARTFrequency</key>
		<false/>
	</dict>
	<key>Devices</key>
	<dict>
		<key>Audio</key>
		<dict>
			<key>AFGLowPowerState</key>
			<true/>
			<key>ResetHDA</key>
			<true/>
		</dict>
		<key>ForceHPET</key>
		<false/>
		<key>HDMIInjection</key>
		<false/>
		<key>InjectHDMI</key>
		<false/>
		<key>InjectLAN</key>
		<false/>
		<key>LANInjection</key>
		<true/>
		<key>USB</key>
		<dict>
			<key>AddClockID</key>
			<false/>
			<key>FixOwnership</key>
			<false/>
			<key>Inject</key>
			<true/>
		</dict>
	</dict>
	<key>GUI</key>
	<dict>
		<key>EmbeddedThemeType</key>
		<string>Dark</string>
		<key>Hide</key>
		<array>
			<string>Preboot</string>
			<string>Legacy</string>
		</array>
		<key>KbdPrevLang</key>
		<true/>
		<key>Language</key>
		<string>en:0</string>
		<key>Mouse</key>
		<dict>
			<key>Enabled</key>
			<true/>
		</dict>
		<key>Scan</key>
		<true/>
		<key>TextOnly</key>
		<true/>
		<key>Theme</key>
		<string>embedded</string>
	</dict>
	<key>Graphics</key>
	<dict>
		<key>Inject</key>
		<dict>
			<key>ATI</key>
			<false/>
			<key>NVidia</key>
			<false/>
		</dict>
		<key>RadeonDeInit</key>
		<false/>
	</dict>
	<key>KernelAndKextPatches</key>
	<dict>
		<key>AppleRTC</key>
		<true/>
		<key>KernelToPatch</key>
		<array>
			<dict>
				<key>Comment</key>
				<string>Disable panic kext logging on 10.13.x Release kernel</string>
				<key>Disabled</key>
				<false/>
				<key>Find</key>
				<data>
				igKEwHRE
				</data>
				<key>MatchOS</key>
				<string>10.13.x</string>
				<key>Replace</key>
				<data>
				igKEwOtE
				</data>
			</dict>
			<dict>
				<key>Comment</key>
				<string>Disable panic kext logging on 10.14.4+ Release kernel</string>
				<key>Disabled</key>
				<false/>
				<key>Find</key>
				<data>
				AIoChMB0
				</data>
				<key>MatchOS</key>
				<string>10.14.x</string>
				<key>Replace</key>
				<data>
				AIoChMDr
				</data>
			</dict>
			<dict>
				<key>Comment</key>
				<string>algrey - commpage_populate -remove rdmsr</string>
				<key>Disabled</key>
				<false/>
				<key>Find</key>
				<data>
				uaABAAAPMg==
				</data>
				<key>MatchOS</key>
				<string>10.13.x,10.14.x</string>
				<key>Replace</key>
				<data>
				Dx+AAAAAAA==
				</data>
			</dict>
			<dict>
				<key>Comment</key>
				<string>algrey - cpu_topology_sort -disable _x86_validate_topology</string>
				<key>Disabled</key>
				<false/>
				<key>Find</key>
				<data>
				6Ar2//+c
				</data>
				<key>MatchOS</key>
				<key>Replace</key>
				<data>
				Dx9EAACc
				</data>
			</dict>
			<dict>
				<key>Comment</key>
				<string>algrey - cpu_topology_sort -disable _x86_validate_topology (10.14.4+)</string>
				<key>Disabled</key>
				<false/>
				<key>Find</key>
				<data>
				6Jn1//8=
				</data>
				<key>MatchOS</key>
				<key>Replace</key>
				<data>
				Dx9EAAA=
				</data>
			</dict>
			<dict>
				<key>Comment</key>
				<string>algrey - cpuid_set_cache_info - cpuid 0x8000001D instead 0</string>
				<key>Disabled</key>
				<false/>
				<key>Find</key>
				<data>
				McAx2zHJMdIPokGJxkGJ0YM9ygWNAAB0GEiNPZKSXwAx
				9jHAQYnIRInyidno6IlYAEGD/gQPgvoBAABFMfbrDGYP
				H4QAAAAAAA==
				</data>
				<key>MatchBuild</key>
				<string>17G65,17G66</string>
				<key>MatchOS</key>
				<string>10.13.6</string>
				<key>Replace</key>
				<data>
				uB0AAIAx2zHJMdIPokGJxkGJ0YM9xwWNAAB0G0iNPY+S
				XwC+HQAAgDHAQYnIRInyidno4olYAEGD/gQPgvQBAABF
				MfbrBg8fAA==
				</data>
			</dict>
			<dict>
				<key>Comment</key>
				<key>Disabled</key>
				<false/>
				<key>Find</key>
				<data>
				McAx2zHJMdIPokGJxkGJ0YM92gaNAAB0GEiNPRmWXwAx
				9jHAQYnIRInyidnouIpYAEGD/gQPgvoBAABFMfbrDGYP
				H4QAAAAAAA==
				</data>
				<string>17G8030</string>
				<key>MatchOS</key>
				<key>Replace</key>
				<data>
				uB0AAIAx2zHJMdIPokGJxkGJ0YM91waNAAB0G0iNPRaW
				XwC+HQAAgDHAQYnIRInyidnosopYAEGD/gQPgvQBAABF
				MfbrBg8fAA==
				</data>
			</dict>
			<dict>
				<key>Comment</key>
				<key>Disabled</key>
				<false/>
				<key>Find</key>
				<data>
				McAx2zHJMdIPokGJxoM93W+YAAB0G0GJ0UiNPRnAZwAx
				9jHAQYnIRInyidnoGBhgAEGD/gQPgvgBAABFMfbrDGYP
				H4QAAAAAAA==
				</data>
				<key>MatchOS</key>
				<string>10.14.6</string>
				<key>Replace</key>
				<data>
				uB0AAIAx2zHJMdIPokGJxkGJ0YM912+YAAB0G0iNPRbA
				ZwC+HQAAgDHAQYnIRInyidnoEhhgAEGD/gQPgvIBAABF
				MfbrBg8fAA==
				</data>
			</dict>
			<dict>
				<key>Comment</key>
				<string>algrey - cpuid_set_cache_info - cpuid 0x8000001D instead 4</string>
				<key>Disabled</key>
				<false/>
				<key>Find</key>
				<data>
				uAQAAABEifFEiQ==
				</data>
				<key>MatchOS</key>
				<key>Replace</key>
				<data>
				uB0AAIBEifFEiQ==
				</data>
			</dict>
			<dict>
				<key>Comment</key>
				<string>algrey - cpuid_set_cache_info - don't set cpuid_cores_per_package</string>
				<key>Disabled</key>
				<false/>
				<key>Find</key>
				<data>
				wega/8A=
				</data>
				<key>MatchOS</key>
				<key>Replace</key>
				<data>
				Dx8A6wY=
				</data>
			</dict>
			<dict>
				<key>Comment</key>
				<string>algrey - cpuid_set_generic_info - remove wrmsr</string>
				<key>Disabled</key>
				<false/>
				<key>Find</key>
				<data>
				uYsAAAAxwDHSDzA=
				</data>
				<key>MatchOS</key>
				<key>Replace</key>
				<data>
				Zg8fhAAAAAAAZpA=
				</data>
			</dict>
			<dict>
				<key>Comment</key>
				<string>algrey - cpuid_set_generic_info - set microcode=186</string>
				<key>Disabled</key>
				<false/>
				<key>Find</key>
				<data>
				uYsAAAAPMg==
				</data>
				<key>MatchOS</key>
				<key>Replace</key>
				<data>
				uroAAABmkA==
				</data>
			</dict>
			<dict>
				<key>Comment</key>
				<string>algrey - cpuid_set_generic_info - set flag=1</string>
				<key>Disabled</key>
				<false/>
				<key>Find</key>
				<data>
				uRcAAAAPMsHqEoDiBw==
				</data>
				<key>MatchOS</key>
				<key>Replace</key>
				<data>
				sgFmDx+EAAAAAABmkA==
				</data>
			</dict>
			<dict>
				<key>Comment</key>
				<string>algrey - cpuid_set_generic_info - disable check to allow leaf7</string>
				<key>Disabled</key>
				<false/>
				<key>Find</key>
				<data>
				ADoPgg==
				</data>
				<key>MatchOS</key>
				<key>Replace</key>
				<data>
				AAAPgg==
				</data>
			</dict>
			<dict>
				<key>Comment</key>
				<string>algrey - cpuid_set_info - GenuineIntel to AuthenticAMD</string>
				<key>Disabled</key>
				<false/>
				<key>Find</key>
				<data>
				R2VudWluZUludGVsAA==
				</data>
				<key>MatchOS</key>
				<key>Replace</key>
				<data>
				QXV0aGVudGljQU1EAA==
				</data>
			</dict>
			<dict>
				<key>Comment</key>
				<string>algrey - cpuid_set_cpufamily - force CPUFAMILY_INTEL_PENRYN</string>
				<key>Disabled</key>
				<false/>
				<key>Find</key>
				<data>
				MduAPbgLjQAGdVw=
				</data>
				<key>MatchOS</key>
				<key>Replace</key>
				<data>
				u7xP6njpXQAAAJA=
				</data>
			</dict>
			<dict>
				<key>Comment</key>
				<key>Disabled</key>
				<false/>
				<key>Find</key>
				<data>
				MduAPagMjQAGdVw=
				</data>
				<key>MatchOS</key>
				<key>Replace</key>
				<data>
				u7xP6njpXQAAAJA=
				</data>
			</dict>
			<dict>
				<key>Comment</key>
				<key>Disabled</key>
				<false/>
				<key>Find</key>
				<data>
				MduAPUh5mAAGdVw=
				</data>
				<key>MatchOS</key>
				<key>Replace</key>
				<data>
				u7xP6njpXQAAAJA=
				</data>
			</dict>
			<dict>
				<key>Comment</key>
				<string>xlnc - cpuid_set_info - grab cores and logicals count from MSR</string>
				<key>Disabled</key>
				<false/>
				<key>Find</key>
				<data>
				PbxP6nh1NosFyAqNAIkFiguNAIsNwAqNAOsW
				</data>
				<key>MatchOS</key>
				<key>Replace</key>
				<data>
				uAgAAIAx2zHJMdIPokGJzkEPtsb/wA8fAOtS
				</data>
			</dict>
			<dict>
				<key>Comment</key>
				<key>Disabled</key>
				<false/>
				<key>Find</key>
				<data>
				PbxP6nh1NosFuAuNAIkFegyNAIsNsAuNAOsW
				</data>
				<key>MatchOS</key>
				<key>Replace</key>
				<data>
				</data>
			</dict>
			<dict>
				<key>Comment</key>
				<key>Disabled</key>
				<false/>
				<key>Find</key>
				<data>
				PbxP6nh1JosFV3iYAIkFGXmYAIsNT3iYAOs4
				</data>
				<key>MatchOS</key>
				<key>Replace</key>
				<data>
				uAgAAIAx2zHJMdIPokGJzkEPtsb/wA8fAOtc
				</data>
			</dict>
			<dict>
				<key>Comment</key>
				<string>xlnc - cpuid_set_info - set cores and logicals count</string>
				<key>Disabled</key>
				<false/>
				<key>Find</key>
				<data>
				iwViCo0AiQUkC40AiwVaCo0AiQUcC40A
				</data>
				<key>MatchOS</key>
				<key>Replace</key>
				<data>
				iQViCo0AiQUkC40AiQVaCo0AiQUcC40A
				</data>
			</dict>
			<dict>
				<key>Comment</key>
				<key>Disabled</key>
				<false/>
				<key>Find</key>
				<data>
				iwVSC40AiQUUDI0AiwVKC40AiQUMDI0A
				</data>
				<key>MatchOS</key>
				<key>Replace</key>
				<data>
				iQVSC40AiQUUDI0AiQVKC40AiQUMDI0A
				</data>
			</dict>
			<dict>
				<key>Comment</key>
				<key>Disabled</key>
				<false/>
				<key>Find</key>
				<data>
				SIsF5neYAEiJBad4mACBPa14mAC8T+p4
				</data>
				<key>MatchOS</key>
				<key>Replace</key>
				<data>
				iQXnd5gAiQWpeJgAiQXfd5gAiQWheJgA
				</data>
			</dict>
			<dict>
				<key>Comment</key>
				<string>algrey - i386_init - remove rdmsr (x3)</string>
				<key>Disabled</key>
				<false/>
				<key>Find</key>
				<data>
				uZkBAAAPMkjB4iCJxkgJ1rmYAQAADzJIweIgicBICcK/
				WAIxBTHJRTHA
				</data>
				<key>MatchOS</key>
				<key>Replace</key>
				<data>
				Zg8fhAAAAAAAZg8fhAAAAAAAZg8fhAAAAAAAZg8fhAAA
				AAAAZg8fRAAA
				</data>
			</dict>
			<dict>
				<key>Comment</key>
				<string>algrey - tsc_init - remove Penryn check to execute default case</string>
				<key>Disabled</key>
				<false/>
				<key>Find</key>
				<data>
				PbxP6ngPhI0BAAA=
				</data>
				<key>MatchOS</key>
				<key>Replace</key>
				<data>
				ZmZmDx+EAAAAAAA=
				</data>
			</dict>
			<dict>
				<key>Comment</key>
				<key>Disabled</key>
				<false/>
				<key>Find</key>
				<data>
				PbxP6ngPhN0BAAA=
				</data>
				<key>MatchOS</key>
				<key>Replace</key>
				<data>
				ZmZmDx+EAAAAAAA=
				</data>
			</dict>
			<dict>
				<key>Comment</key>
				<string>xlnc - tsc_init - grab DID and FID from MSR</string>
				<key>Disabled</key>
				<false/>
				<key>Find</key>
				<data>
				uZQBAAAPMonDuc4AAAAPMg+2zokNcKmFAA+2xIkFa6mF
				AA==
				</data>
				<key>MatchOS</key>
				<key>Replace</key>
				<data>
				uXEAAcAPMonASInBSMHpBoPgP0iDwBCA4QdI0+hI0ehm
				kA==
				</data>
			</dict>
			<dict>
				<key>Comment</key>
				<key>Disabled</key>
				<false/>
				<key>Find</key>
				<data>
				uZQBAAAPMonDuc4AAAAPMg+2zokN2KiFAA+2xIkF06iF
				AA==
				</data>
				<key>MatchOS</key>
				<key>Replace</key>
				<data>
				kA==
				</data>
			</dict>
			<dict>
				<key>Comment</key>
				<string>algrey - tsc_init - grab DID and FID from MSR</string>
				<key>Disabled</key>
				<false/>
				<key>Find</key>
				<data>
				uZQBAAAPMonDuc4AAAAPMg+2zokNst+QAA+2xIkFrd+Q
				AA==
				</data>
				<key>MatchOS</key>
				<key>Replace</key>
				<data>
				kA==
				</data>
			</dict>
			<dict>
				<key>Comment</key>
				<string>algrey - tsc_init - skip test and go get FSBFrequency</string>
				<key>Disabled</key>
				<false/>
				<key>Find</key>
				<data>
				SIkFRKmFAPfDAAABAHQ=
				</data>
				<key>MatchOS</key>
				<key>Replace</key>
				<data>
				SIkFRKmFAGYPH0QAAOs=
				</data>
			</dict>
			<dict>
				<key>Comment</key>
				<key>Disabled</key>
				<false/>
				<key>Find</key>
				<data>
				SIkFrKiFAPfDAAABAHQ=
				</data>
				<key>MatchOS</key>
				<key>Replace</key>
				<data>
				SIkFrKiFAGYPH0QAAOs=
				</data>
			</dict>
			<dict>
				<key>Comment</key>
				<key>Disabled</key>
				<false/>
				<key>Find</key>
				<data>
				SIkFht+QAPfDAAABAHQ=
				</data>
				<key>MatchOS</key>
				<key>Replace</key>
				<data>
				SIkFht+QAGYPH0QAAOs=
				</data>
			</dict>
			<dict>
				<key>Comment</key>
				<string>algrey - lapic_init - remove version check and panic</string>
				<key>Disabled</key>
				<false/>
				<key>Find</key>
				<data>
				JfwAAACD+BM=
				</data>
				<key>MatchOS</key>
				<key>Replace</key>
				<data>
				JfAAAADrI5A=
				</data>
			</dict>
			<dict>
				<key>Comment</key>
				<string>algrey - lapic_interrupt - skip checks and prevent panic</string>
				<key>Disabled</key>
				<false/>
				<key>Find</key>
				<data>
				gz2UlnAAAHQK
				</data>
				<key>MatchOS</key>
				<key>Replace</key>
				<data>
				60gPH4AAAAAA
				</data>
			</dict>
			<dict>
				<key>Comment</key>
				<key>Disabled</key>
				<false/>
				<key>Find</key>
				<data>
				gz3UlXAAAHQK
				</data>
				<key>MatchOS</key>
				<key>Replace</key>
				<data>
				60gPH4AAAAAA
				</data>
			</dict>
			<dict>
				<key>Comment</key>
				<key>Disabled</key>
				<false/>
				<key>Find</key>
				<data>
				gz31zXsAAHQK
				</data>
				<key>MatchOS</key>
				<key>Replace</key>
				<data>
				60gPH4AAAAAA
				</data>
			</dict>
			<dict>
				<key>Comment</key>
				<string>algrey - mtrr_update_action - fix PAT (x2)</string>
				<key>Disabled</key>
				<false/>
				<key>Find</key>
				<data>
				icCB4v//8P+BygAAAQC5dwIAAA==
				</data>
				<key>MatchOS</key>
				<key>Replace</key>
				<data>
				uXcCAAC4BgEHALoGAQcADx9AAA==
				</data>
			</dict>
			<dict>
				<key>Comment</key>
				<string>algrey - mtrr_update_action - fix PAT (x2) (10.14.4+)</string>
				<key>Disabled</key>
				<false/>
				<key>Find</key>
				<data>
				icCB4v//AP+BygAAAQC5dwIAAA==
				</data>
				<key>MatchOS</key>
				<key>Replace</key>
				<data>
				</data>
			</dict>
		</array>
	</dict>
	<key>RtVariables</key>
	<dict>
		<key>BooterConfig</key>
		<string>0x28</string>
		<key>CsrActiveConfig</key>
		<string>0x67</string>
		<key>ROM</key>
		<string>UseMacAddr0</string>
	</dict>
	<key>SMBIOS</key>
	<dict>
		<key>BiosReleaseDate</key>
		<string>12/19/2018</string>
		<key>BiosVendor</key>
		<string>Apple Inc.</string>
		<key>BiosVersion</key>
		<string>IM142.88Z.F000.B00.1812191208</string>
		<key>Board-ID</key>
		<string><!--hidden--></string>
		<key>BoardManufacturer</key>
		<key>BoardType</key>
		<integer>10</integer>
		<key>BoardVersion</key>
		<string>1.0</string>
		<key>ChassisAssetTag</key>
		<string>iMac-Aluminum</string>
		<key>ChassisManufacturer</key>
		<key>ChassisType</key>
		<string>0x0D</string>
		<key>EfiVersion</key>
		<string>134.0.0.0.0</string>
		<key>Family</key>
		<string>iMac</string>
		<key>FirmwareFeatures</key>
		<string>0xE00FE137</string>
		<key>FirmwareFeaturesMask</key>
		<string>0xFF1FFF3F</string>
		<key>LocationInChassis</key>
		<string>Part Component</string>
		<key>Manufacturer</key>
		<key>Mobile</key>
		<false/>
		<key>PlatformFeature</key>
		<string>0x01</string>
		<key>ProductName</key>
		<string>iMac14,2</string>
		<key>Trust</key>
		<true/>
		<key>Version</key>
	</dict>
	<key>SystemParameters</key>
	<dict>
		<key>InjectKexts</key>
		<string>Yes</string>
		<key>InjectSystemID</key>
		<true/>
		<key>NvidiaWeb</key>
		<true/>
	</dict>
</dict>
</plist>
FakeSMC.kext
IONetworkingFamily.kext
Lilu.kext
NullCPUPowerManagement.kext
WhateverGreen.kext
XLNCUSBFix.kext
Hi everybody!
Found the cause!!
I have two HDD attached to my mobo. Removing them made it full speed!! WOW!
But now, I have one question: how to ignore my HDDs without unplugging them?
Re: File System / GUI delays and lags [PARTIALLY SOLVED]
And one more question: how to change the macOS drive SATA port? Clover couldn't find the drive when SATA changed.
Well, I was wrong.
The problem continues. I think the root cause is related to the disk.
Any help?
Re: File System / GUI delays and lags [PROBLEM CONTINUES]
Well, I reinstalled the OS without converting to APFS and it's full speed now!
Closing this topic.
by: PeeJay
#50952
I've got the same problem. I tried reinstalling without apfs, but that made no difference. Removing a sata disk didn't work, removing a nvme disk seems to have reduced how often it happens, but it still happens every few minutes. Is there any log files I can check? It's definately disk related because as soon as the computer becomes responsive again the disk activity light comes on. Google chrome says "waiting for cache" when it happens.
For anyone else with the same problem, using a different brand disk was the fix. For some reason osx just doesn't like my "Samsung 840", even with the latest firmware.
Hello everyone, I am trying to install MacOS to my[…]
"I managed to get through that and installed […]
Good question: I've extracted the Titan Ridge[…]
Could you share your new efi to me, thank you!My[…]
