#50693
I'm using a usb sound card too and I do get the choppy sound. Same when using a bluetooth headphone.
I think it's an issue with the kernel, or with the g cards. Seems like this is where all the problems come from.
I'm on the 3200g.
My soundcard and usb hub are not detected when i plug it them into a usb3 slot. Mouse however, works fine on usb3. Usb 3.1 is fine as well.
"I managed to get through that and installed […]
Good question: I've extracted the Titan Ridge[…]
Could you share your new efi to me, thank you!My[…]
Big thanks to Anti for publishing his EFI Folder. […]
