#50620
Hi,
i want to know if my old pc with this specs work:
AMD FX-8320
16,0GB Single-Channel DDR3 @ 669MHz (9-9-9-24)
Gigabyte Technology Co. Ltd. 970A-UD3P
2048MB ATI AMD Radeon R9 200 Series (Sapphire/PCPartner)
232GB Samsung SSD 850 EVO 250GB
if work wich osx can run?
thx :D
#50622
hello,
the CPU has been know to be hackingtosh compatible .
the ram will work but the single channel will hurt performance massively.
the gpu is supported inc liquid metal so should be ok for newer updates.
you should be able to run high seira and on wards but might be slow due to single channel ram.
Hello! I realize this isn't quite a "Success […]
64bit app no working
I'm a few months late but I'll comment as I actual[…]
I'm trying to install Catalina 10.15.1 onto my ne[…]
