#50519
Specs:
CPU: AMD Ryzen 5 3600
Motherboard: MSI B450M Mortar
RAM: 1x Hyper Savage DDR4 2133 mhz + 1x Gskill Aegis DDR 2132 mhz
SSD: Crucial BX500 240 GB - Sandisk Ultra II 240 Gb
GPU: Sapphire Nitro RX570 4 GB
Sound: Motherboard
Successfully flashed the B450M using the Bios Flashback and started using it with the new Ryzen 5 3600.
I followed this guide: https://hack.slim.ovh/#/mojave
This is my second hackintosh build. It was fairly easy, basically was no different than doing a Hackintosh with Intel CPU. My ethernet and my sound was working right out of the box. iMessage and App Store works fine as well. Just installed Xcode and I'm ready to roll.
Here is the Geekbench result I've just ran: https://browser.geekbench.com/v4/cpu/14181216
As I use it daily, I am noticing some things not working. Such as
- Sleep
- Audio stutters sometimes
- Cpu listed as unknown and there are no sensor info such as temperature, voltage or fan speed
Those don't effect me right now but I would like to be able to fix them as I get involve with the community.
#50521
Hi, I'm building a second hackintosh, I already successfully installed following an outdated guide posted here by @comacon user. But I really would like to try vanilla installations. Since I do not have windows on any machine of mine and I do not intend to download all of these softwares to create a bootable Mojave USB, I will try following this guide you've mentioned as well.
My new build:
MSI B450M PRO M2 (https://www.msi.com/Motherboard/B450M-PRO-M2)
Ryzen 5 1600
Patriot SSD 120 GB (Mojave)
Sandisk SSD 120 GB (Debian Linux)
Which version did you install? The guide provides 10.14.1 and 10.14.4.
Do you think you'll be able to update?
Thanks for sharing and good luck with you AMD hackintosh. :thumbup:
#50525
let us know any news on success or failure and have fun!
I followed the same guide as you: https://hack.slim.ovh/#/mojave and everything went fine.
#50554
You can compare any AMD processor in here :arrow: https://www.amd.com/pt/products/specifi ... processors
Here is the comparison between 3600 and 3600x :arrow: https://www.amd.com/pt/products/specifi ... /8451,8456
Hello everyone, I am trying to install MacOS to my[…]
"I managed to get through that and installed […]
Good question: I've extracted the Titan Ridge[…]
Could you share your new efi to me, thank you!My[…]
